Problem:Car not Starting*Installed Walbro Fuel Pump
  • Problem:Car not Starting*Installed Walbro Fuel Pump
    Okay we'll i end up installing a walbro fuel pump in my car , & know the car not starting over , you here the fuel pump priming over but the car just not starting . .I had a half a tank before i took out the old fuel pump & the car still reading a half a tank , so i dont think its Gas problem . .& everything has been installed correct . .
    Need some Advice ASAP . .
    98Ex DD EJ8 ROADRUNNER
    New or used?
      Originally posted by 93eg2sol View Post
      New or used?
      Used , but I got it from my mechanic/tuner . .
        Oh man gl bro
          If installed correctly , must be a bad pump...
            Have u put in the old pump and c wat happens?
              Originally posted by SeanJDMJohn View Post
              Oh man gl bro
              Word
              Used ain't always good
              It's 120 brand new
                Originally posted by Boosthead90 View Post
                Word
                It's 120 brand new
                Less
                  Ima try in the morninq & see , hopefully it'd the Pump cause I did some research & this one guy had the same problem ,but he installed his old one & it'd still ain't start over , it ended up being his dizzy
                    what did u take apart besides the fuel pump assembly
                      Even better less than 120
                      Can't go wrong now you doing the job twice
                        On ek isn't in under the Seat if so reinstall your stock pump an see from there Then you know for sure what the problem
                          Check fuel pressure....
                            Does the motor turn over?...my old da9 never wanted to start it was the dizzy that would go bad and the inginitor under the dash
                              75% sure you put the positive and negative backwards .. The pump turning on but running backwards..... Switch the polarity
