CEL code
  • CEL code
    so its a learning process with this fuckin swap. took it out for the first test drive today and around 3-4k rpm it just loses power. stays running but just has nothin to it. my boy said it may be the tps, idk. ran a cel check today and i cant figure out wtf it is so i had to post a vid if you know what codes its throwin please let me know thanks. ecu is p28
    That srs would make me punch my cluster seriously
      lmaoo it only does that when you check cel
        I have a book on this shit but I can't find it
          if i read the codes right,its 41 and 10...41=o2 sensor heater and 10=iat sensor........
          R.I.P NHSWAPS13203
            I was thinking the same thing
              41 is probably right, and would the iat cause my problem??
                check the wire color on the iat plug,should be a red/yellow and green/black....you might have it swapped with the purge valve plug....
                R.I.P NHSWAPS13203
