i have an obd0 b18a1,oem everything,just did the timing belt and now i cannot get the timing to set corrctly,im setting the cams to te right position,and the crank pulley mark to the TDC position,everytime i spin the motor,it jumps teeth,what could be the problem?
timing
make sure the tensioner is ok and also make sure theres no stripped teeth on the belt860 member #18
puerto roc #1
Cosa nostra
ASAPRadio.net
"Hatred is the coward's revenge for being intimidated.â€
