My motor on my 93 da blew so i bought a b18b1 put it in but when i try to start it all my grounds heat up and it just clickscar is auto by the way
help car ont start heating grounds
there is only two reasons it will do this one is you have a power wire touching the block some place other reason it because you dont have enought ground and the yo uare over working the few you have add more fround and try again if you have a power wire shorting out most likely it will pop a fuse first... add grounds and try againRIP Nick
yes the motor wont crank because the starter has 12v at it and the only ground it has is threw the motor and threw the ground off the motor to the frame if they are dirty or you dont have enough of them they that will happen the most importen one is the one from the transmission to the frame and the more you have the better ... try itRIP Nick
like he said tanny to frame is most important and check power fro starter make sure its not touching anything
