gsr tranny question (tranny rebuilders input needed)
  • gsr tranny question (tranny rebuilders input needed)
    ok heres the deal, my gsr tranny on rare occasions at high rpm has the slightest grind in second like once every twenty times. i switched to pennzoil syncromesh and it cleared it up but my case leaks so it came back after a while
    ok so my question is do i need to replace the synchro and spring or both and the gear itself
    every other gear is fine whether upshifting or down shifting
    also ill be doing the work myself to save money and seeing ive ripped my friends tranny apart to put a new diff in it and new main input shaft bearing so i know how to disassemble it and reassemble
      i think you would have to open it up... see what the damage is and go from there... but im no pro lol
        im too lazy to rip it apart just to reseal it so it stops leaking lol
          I think just synchros n you'll be good
            thats what im hoping and if i do fix it im gonna go with a carbon coated 2nd synchro
              My car would spit out 2nd all the time I changed the synchro n it was brand new
                see mine it grabs there gear fine just on rare occasions when banging gears it will grind a little but still go in gear it was fine when i switched to syncromesh until it all leaked out lol
                  where's mr niceguy lol
                    ttttttttttttttttttt
                      ttttttttttt
                        ttttttttttttttttttt
                          ttttttttttttttttttt
                            tttttttttttttttttttttttttt
                              Your Syncro failed which has started making the 1st/2nd sleeve grind against the 2nd gear engagement teeth, during 2nd gear engagement. The fact that it only happens once in a great while, you may be safe with replacing just the Syncro. But you'll probably find the gear, sleeve, Syncro, & Syncro spring all worn to replacement level.
                              Hope I was able to help, if you need any other assistance PM me. Or I'll do the job for you, for an unbeatable price.
