Wiring harness help ???
  • Wiring harness help ???
    Hey guys thanks for looking in advance, I was wondering if it would make a difference if I use a wiring harness from a auto on my 5 sp, it's the same motor ? I just did a swap and my car don't wanna start, maybe that's why ?
    I think the only difference between a auto nd 5 speed engine harness , is the ecu plug , there's a extra one , I can prolly be wrong but that's what I heard .. and something else with the tranny plug too . .but g/l bro . Check google as well if you don't fine no answers in enough tyme
    98Ex DD EJ8 ROADRUNNER
      if its an eg harness should still work not too sure on ek's tho...
      post more info like the car what harness what motor... is the car getting spark? fuel?
        U need to make sure the gear selector was in neutraul
        Follow me @bolacan413
        Follow the build @k_insight
          x10000000 happened to me cant believe it slipped my mind
            It's for a Ls and it's in a 4 door, make any difference !?
              you can use it. it is all the same other then the extra plugs for the transmission and if in a EK one extra ecu plug the car will run no prob. done it a few times
