so i was talking to someone and they were saying that because my car is a ex that it should be already wired to the shock tower for vtec??? I was told the only thing i would have to wire is the knock sensor.
does this all make sense to you??
because my ecu is a obd1 jdm p72 does it have the knock sensor programmed?
the ex is wired for vtec for factory...if the swap is a gsr and your keeping the stock intake manifold then you will have to wire in the iab's...if you throw a code and its for knock then wire in the knock sensor.....those are the only two things that need to be wired in...
Gl said all I can possibly tell u I got my knock sensor unplugged right now no code just went out nd ran that fucker but hey if u need real help u got my number
intake air bypass control solenoid valve and its only for a gsr motor....if you have a gsr motor and dont want to have to wire in the iab then get an after market intake manifold..
Im glad that ur willing to help and yep i got ur number
how do i get the 12volts from a switch source??? what would u use
i would put a wire in the plug on the drivers side that has a plug in it,its got a few yellow/black wires in it.....only one of them has power though,the rest get it from that one wire when that cap plug is in the plug..
