Help!!!!!!! b18c swap questions
  • #16
    Originally posted by jdmjunkie9753 View Post
    If its an obd1 p72 then it doesn't look for a knock sensor. I had a 97 spec JDM ITR swap in my ej1 running on a stock obd1 p72 and it ran mint no problems at all.
    i had an obd-1 us p72 ecu in my eg with a b-swap and it in fact did throw a code for knock when not hooked up......
    R.I.P NHSWAPS13203
    • #17
      Thats wierd because the only CEL I had was for an o2 sensor because I was running one piece ceramic headers..
      • #18
        Originally posted by ls94civic View Post
        Does anybody know where i can get a printable copy of the computer pinout
        anyone?
        • #19
          use the harness thats in the car on the motor. If you have a OBD2 dizzy, just de pin the dist. and put a OBD1 plug on the end. or the other way around, doesnt matter.
          Use ur b18a alt so it plugs rite in.You might have to wire ur knock. But its a single wire, so its easy.
          Use your b18a injectors.
          Honda ECU Pinouts OBD 0 Pinout '88 HF/Si '90-1 DX (Std.) '90-1 HF/Si '89-92 EF8/9 SiR A1 No.1 INJ Aux INJ w/A3 No.1 INJ No.1 INJ A2 GRD w/A4 to Main Relay GRD w/A4 to Main Relay GRD w/A4 to Main Relay GRD w/A4 to Main Relay A3 No.2 INJ Aux INJ w/A1 No.2 INJ No.2 INJ A4 GRD w/A2 to...
          • #20
            and your throttle body will work just fine.
            Between the 2 motors you have, you shouldnt spend another dollar on anything but a computer.
            • #21
              i bought a jdm obd1 p 72
              • #22
                why do you want to make it hard and hack shit up?the obd-2 integra harness s plug and plug for the 92-95 civic,just need to wire in a few thing that are not hard to do.....
                R.I.P NHSWAPS13203
                • #23
                  ^^^exactly what i was thinking
                  • #24
                    doesnt have to be hacked, but do it either way. It doesnt matter.
                    • #25
                      the pins are different between obd-1 and obd-2,so how you gonna hook them up with out hacking them up...
                      R.I.P NHSWAPS13203
                      • #26
                        so i was talking to someone and they were saying that because my car is a ex that it should be already wired to the shock tower for vtec??? I was told the only thing i would have to wire is the knock sensor.
                        does this all make sense to you??
                        because my ecu is a obd1 jdm p72 does it have the knock sensor programmed?
                        • #27
                          harness will work if USDM. no need to wire knock sensor if your using obd1 ECU... no wiring plug and play
                          • #28
                            use a p28 or USDM obd1 p72
                            • #29
                              Bump g/l . . .
                              98Ex DD EJ8 ROADRUNNER
                              • #30
                                Thanx for ur input nd I'm serious I don't think u need to wire a knock just tho ur swap in keep everything Obd2 use ur jdm ecu nd if it throws a code just check it nd if its cause of the knock then wire it in most ppl just don't use there is a write up on Honda tech to eliminate it
                                Nd here is another person that knows
