Search in B Series Tech only
advanced_search-1
Technical Forums
B Series Tech
!!! Help/question !!!
chuchii
Member
Jun 2010
05-30-2011, 11:52 PM
Does any one know if a h22 6 put cluch fits a b serious tranny- preasure plate & flywheel,, ????
ALSO WHATS TH DIFFERENCE BETWEEN A STOCK CLUCH ND A SIX PUT CLUCK
djkiley
Mar 2010
05-30-2011, 11:53 PM
b serious!
chuchii
Member
Jun 2010
05-30-2011, 11:56 PM
djkiley
b serious!
yes,, h22 on a b serious,,, would it work
mark95
Jan 2009
05-30-2011, 11:57 PM
just the clutch or the whole kit
eh9 jdm b16
Pimpbays
chuchii
Member
Jun 2010
Just th cluch,,
chuchii
Member
Jun 2010
05-31-2011, 12:26 AM
B16eg6
Mar 2009
05-31-2011, 12:29 AM
No. The center spline on the H22 is totally different than a B series.
The H22 Flywheel is also about 1" larger in diameter so im going to say NO. You need to go with an H series clutch.
RIP NHSWAPS13
chuchii
Member
Jun 2010
05-31-2011, 01:38 AM
B16eg6
Wt im wondering is if i can put an h22 clutch on a b series motor with th regular b series preasure plate nd flywheel,,,
Hi ppl
Banned
May 2011
05-31-2011, 01:41 AM
na
B16eg6
Mar 2009
05-31-2011, 09:21 AM
chuchii
And what i said in my original post is NO.
The center spline on the actual disk is different AS WELL AS the actual clutch disk being 1" larger in diameter.
B series clutch will only work on B series. H series will only work on H and F series.
RIP NHSWAPS13
Close
