need help
  • need help
    ok to sart it off i just swapped my hatch and everything runs fine and idles perfect my question is will a 02 sensor make a ecu go into limp mode becuase that is tha only code my car is throwing
    any help would be appriciated
    no, need more details.
    (860) and beyond
    #DavesTuning 8608050968
      ok, well thats the only code that the ecu throws its code 41 to be exact ive tryed 2 different ecu's and still is in limp mode ive reset tha ecu like three times and still code 41 came up theres no vaccum leaks or any of the sort it idles perfect and runs with no skip just dosent pass 3500 rpms tha motor is a jdm b20 in a ef hatch converted to obd1 with a p06 ecu and ive also tried a pr4 and a p75 and still the same
        Dizzy wiring is wrong
        (860) and beyond
          ohh okk thanx ima go try to fix now is there any way u can mix up tha cps and tha tdc sensor wires?? will the car still start?
