B20 oil freeze plugs
  • B20 oil freeze plugs
    So I wanna put a catch can on my b2o v. I purchased the prelude freeze plugs. Now I wanna know what size allen key are those fuckers. Thanks in advance
    Follow me @bolacan413
    Follow the build @k_insight
    14mm i can dubble check when i get outta work
    WILSON BUILT
      Aigh thanks a write up said 14mm
        You know what it is a 14mm craftsman sells it in a kit an not as a single socket
        WILSON BUILT
          how much is it ??
            Well i got mine from a friend..sears wanted like 50$ for the set an i wasnt paying that much
            WILSON BUILT
              i need to do the same lol
                So I comfirmed is a 14mm allen for all you interested
                  ya 14mm best bet is ebay cuz i looked every were for that allen, ebay had it for 10 shipped
                    I went to Habor freight today and picked up a set of allen wrenches on 1/2 and 3/8 sockets for 15$, not bad compared to other prices. I believe it goes up to 17mm. Cus the lock tight on there is a bitty lol
                      This is the snap on 14mm I used for the passenger side one before I bought the kit. I don't recommend it. Use the socket
                      and the oil plugs
                      I ended up having a hard time with the one closest to the altenator almost stripped it, as seen in pic, I removed my alt and harness just to get a better positon, I suggest you save the headache I went thru and just get the socket with the 14mm allen.
                      Engine bay pic after everything was put back in.
