couple questions on ls swap
  • couple questions on ls swap
    finaly got my ls swap. got a 95 ls swap and putting it into my ek. got everything i need but my question is about the harness. i use my harness from my car and i have a jumper harness to run a obd1 ecu but what will i have to change on the motor side of things. need to know asap
    if everything on ur motor is OBD1, then all u need is the jumper harness
      did you forget about the dizzy and alt and injectors? op you will need to use an obd2 alt,inectors,and dizzy or get a jump for the dizzy like this one http://www.summitracing.com/parts/MSD-8864/
      R.I.P NHSWAPS13203
        thanks for the info...so after i change the motor over to obd2 i will still have to use the ecu jumper harness
