intake manifold help
  • intake manifold help
    Ok so I hav a 94 b18b wit a 97 intake manifold I believe (it has a black thing on top of it). I hav a 97 d16y7 5 speed engine harness and the harness has different map sensor plug and idle plug than the intake manifold. Help?
    Originally posted by nano0222
    The black thigh on the top is evap purg and the idcv is different because the y7 is a three wire and the b series is two wire if you Google it there is a how to write up on ffsquad how to swap it over the map sensor plugs are the same
      i know how to fix it just buy a new wire haarness i got one obd2 let me know
      R.I.P NHSWAPS....BPT CT
        New wire harness won't do any good if the car is wired for a three wire iacv nothing will shut the light off but re wiring it the right way
          It's a ek so the harness goes all the way to the ecu. But you can convert it from a 3wire IACV to a 2wire IACV shits easy. Like cake work.
            Ok I have a 3prong on the harness for the iac plug idle air contrl. The intake has a 2prong. Any ideas
              Yes. Like I said. Convert it to a 2wire IACV.
                How?
                  it's for the midori? obd2a?
                    google it dude its easy jus buy the 2 wire plug nd change it over wires are color matched discard the orange wire it isnt used
                    White ek hatch
                      Yea obd2a trying 2 convert 2 a obd1 intake
                        Bro that intake isn't obd1 its obd2 I am tellin u man
                          If you have a black thing on top of your manifold then it's obd2. But that doesn't matter. Cuz obd0,1,2 all sue a 2 wire Iacv. So you gotta convert from 3 wire to 2 wire.
                            X2 that's why I said why would he convert
                              Ohh yeah nd I got the plug u just gotta depin it nd plug the pins back in nd ur good
