Lsvtec sanwich plate
  • Lsvtec sanwich plate
    got some oil leaking from lsvtec kit or oil filter, any experiences or thoughts?
    On tight but not too tight. seemes to build pressure then blow by oil filter gasket.
    had some leaking from mine one time from the screw.
    also the gasket is cheap it blows out the one on the plate..
      Did u lube up the rubber gasket on the oil filter before installing
        yea everything done right but its a used lsvtec kit so gonna take apart tmrw i guess
        thanks
          yea was wondering if golden eagles are better than others or all same
          i have blackworks, suspect blockage or oring fail
            yeah i got a golden eagle one and it leaked on me too! havent check it for a couple days cuz my car just sitting here. but imma try and move it and see if it still leaks. i think the oring/gasket on them suck!
            ~StayinFRESHSINCE1982~
            SPUNKY MONKEY CREW MEMBER #1
            203 CREW MEMBER #33
