stupid idling help!!!
  • stupid idling help!!!
    i just put a ls swap in my bubble I blead the coolant and everything but now it idles to 3 back to 1 and it keeps doing it wat could it be? i think its a sensor but i really dont know
    you didn't bleed it properly thats all it is ..
      I did cause it has no more air
        vaccum leak or bad iacv. Could be a lot of things. Take the intake off. And while the car is running put your hand over the throttle body and see if it turns off. If it doesn't then you have a vaccum leak. Make sure you have the right plug plugged into your iacv. And not the egr valve plug or w/e that shit is called.
          does it rev up fine?
          ~StayinFRESHSINCE1982~
          SPUNKY MONKEY CREW MEMBER #1
          203 CREW MEMBER #33
            it revs gd
              so the plugs arent switched over, might be a vacuum leak. take a can of carb cleaner, and spray until you hear the idle go down, spray it where ever vacuum goes to.
              203 CREW MEMBER #33
                I did the throttle body shyt and it turned off i didnt check the plugs though ima check that in c
                  If u have a red and yellow wire plug into ur iacv then thats the wrong plug. I forget what color wire the iacv plug is but im pretty sure it's blue and black wires.
                    While I was bleeding the coolant i notice i had a hole in one of the hose i changed the hoes it was one of the hose that was connected to the throttle body should i flush and refill the coolant and bleed again?
                      ima check
                        Yo lsvtec the plugs are right and it has no vacuum leak wat else could it be?
                          What kinda throttle body u got on it it could be the fast idle thermo valve on the bottom of the throttle body take it off nd if its bad it will rattle same shit was wrong on my old ls
                            I have an obd2 throttle body
                              Ohh Iight so there is no fast idle Iight well then Idk bump for Google no offence its quicker then waiting for ppl to tell u what's good u kno
