gsr swap
  • gsr swap
    just a easy question for you guys, if im alreasy ran for vtec in a eg do i still need to change the harness to put in a GSR??
    You could use a sohc vtec ls or gsr depends on what ecu you running I ran mine direct from the inside harness one for the oil pressure and one for VTEC solinoid and it popps with P28 sohc vtec no chips or nuttin ................. yet
      i mean like is everything gonna jsut plug in or would i be better off goin to a teggy harness?
        its plug n play ..... plug ur gsr motor harness into the harness right near the battery its like 3-4 plugs and ur all set... u dont have to change the interior harness .. all egs have vtec prewired
        " Mr. Tough Guy "
