ls/vtec compression test issues
  • ls/vtec compression test issues
    okay so i put my head and block together and tried to do a compression test by hand turning it and can only get the gauge up to 60 psi, only the head and block are mounted, the timing belt isnt hooked up and i am turning it over by hand
    You should really have the belt on, it is what controls the opening and closing of the valves.. without that you won't even come close to getting a proper compression reading.
      okay thats what i thought, i got scared for a second, thanks
        i think your engine is interference engine and by turning the crank and cams seperately can actually bend your valves!i hope i am wrong on this one man good luck .
        CGP CL9
        1993 EH3
          lol it is an interference engine but hes not gonna bend anything turning it by hand
            lol yea u deff need the belt on... car should b on to get good results..
            www.solavei.com/lopez2333
