B18 throttle problem
  • B18 throttle problem
    Under full throttle the motor basically cuts out but If I give it 90% it runs fine what could the problem be?
    91 DB1 Integra ls/vtec built raced broken and rebuilt
    what motor setup/ecu?
      Injectors? Could be a feul problem
      Originally posted by ct tibby
        It's a stock ls... What I forgot to tell you was I had a headgasket changed out. I would say a fuel problem to but it has no problem using more gas then my v6 mx6
