help with 3 codes on my b16
  • help with 3 codes on my b16
    i gotta go for a retest for emissions i have a month left i have 3 check engine codes tat im try to get solved....i re did my whole dash harness and used a si harness for the extra o2 since im running the b16 ecu and didnt wanna run wires and pin out my ecu for the o2 i wanted to do it the right way...my hatch is orginally 00 so it obd2b and i am using an obd2b si engine harness as well as the dash harness..both o2's are plugged in so idk wat it could be just need some help im trying to get rid of my check engine light......
    po131:o2 sensor circuit low voltage bank 1 sensor 1
    p1337:manufacturer controlled ignition system or misfire
    po141:02 sensor heater circuit bank 1 sensor 2
    Ek coupe-stolen
    Ek hatch-sold
    eg bubble-dd
    codes
    are the o2 sensors reading and d you have a test pipe also you what dizzy are you using obd1
      both o2's are reading no test pipe and its all obd2
      Ek coupe-stolen
      Ek hatch-sold
      eg bubble-dd
        sounds like you need to change the o2;s
          i was told the o2 could just be hanging out....is tat true????
          Ek coupe-stolen
          Ek hatch-sold
          eg bubble-dd
            Come let's get my bois check engine light off. We been messin with it for a month now. Its startin to piss me off now lol
            Go kick a boulder
              Ek coupe-stolen
              Ek hatch-sold
              eg bubble-dd
                It def sounds like a wiring issue. No power to the primary o2 & no power to the secondary o2 heater circuit/or bad sensor.
                Can you read schematics & a multimeter? If so, test from your o2 connectors back to the pcm. You should find your problem.
