Ok so i got ctr pistons 81.5mm i think and i have both ls(b18b1) and a b16 blocks... I really wanna build a lsv setup but i heard if i put these in the ls itll make too much compression... Dont kno if this is true so im here to see what people have to say... Which rods and crank should i go with?? Any input would help...
Which block should i use???
Originally posted by spoon860 View PostDo the ls/v the b16 has a short strock and ur not going to make mutch power... With those pistons in the ls block compression would be right around 12.5:1 witch is still pump gas but only run 93B SERIES INC....
