I put my motor in my crx. And it runs like shit because it's not running on a map sensor. When I unplug the map sensor it doesn't change anything and I know the sensor is good. What I need help with is figuring out which wre goes where. I havd White, Yellow/Red and Green/white. I need to know what wire goes to what pin on the ecu plugs. It is for a DPFI Car. I fuess it is not the same from a crx si (mpfi). Thanks for any help!
EF Map Sensor Wiring Help
Originally posted by CTgoldhatch View Postmapp wires are all the same on the EF comeing out of the ecu
c11
c14
c15Money ain't a thing! Crew Member #1
no you cant because the mpfi harness has a built in resustor box different injector plugs as well as 2 more and a different dizz plug because it have 2 more wires to it. nothing baout the mapp sensor changes tho.
turn your key on and get the volt meater out and chack the pin at the map sensor. you sould have 5 volts at one ground at another.
also i know threw the years some car came with a map sesors wire built in to the car harness and some inthe motor harness make sure your harness is out of the right yearRIP Nick
Yea. My map sensor is built to the car harness(on firewall) along with the dpfi harness I put in,. The kid I got the car from tried wiring it dpfi to mpfi and it was a major fail. So I am going back and fixing all his hack jobs. So it's a bitch to do. But thanks for the pinouts im gonna go try and wire it right to the ecu and see if that changes anything.Money ain't a thing! Crew Member #1
I have no where to get it faxed to but thanks for the offer. Im really hoping that when I wireit in tomorrow it fixes the problem! I hate trying to fix other peoples hack jobs. BTW do you have a sohc rear mount setup, like the mount and bracket that goes from mount to tranny?Money ain't a thing! Crew Member #1
Originally posted by blk_cd7 View Postyo the map sensor wires should be the same dp/mp...the only diff is the dizzy and the injectorsMoney ain't a thing! Crew Member #1
