no spark... need help...
  • no spark... need help...
    heres the deal.. GSR swap in an ek car always ran mint. changed spark plugs (same kind that are already in ngk bkr6) ran fine. parked the car went to sleep woke up.. wont start.. checked everything out and there is no spark, all the fuses are fine grounds are good tried diferent wires...
    any ideas car ran perfect when i parked it last night what could cause this to just happen.. can the dizzy just go bad over night? wtf
    main relay or dizzy
      The reason this has happened to you is because you are Brad, and cars don't like you......
        samething i was thinking... main relay or dizzy
          i know wtf.. get this.. on top of everything the rsx is fuel cutting 3k.. just started this morning
          and my girls pulling the dizzy off now to bring it to autozone to get tested.. wtf i dont get it shit ran mint when i parked it last night
            make sure you check your main relay!
              if the main relay is no good the fuel pump would not kick in correct
                fuel pump can still be bad if main relay is clicking or do u mean or aint clicking?
                TurboMannyRacing
                  no no the fuel pump is turning on
                    couldn't have said it any better lol
                      bad coil? or igniter? put a new dizzyyyyyyyyy and see if it works.
                        TurboMannyRacing
                          too lol.. took it down to autozone and they tested the coil witch = FAIL! gaz already replaced the coil and its all good now :) holla
                          on a side note i think my head gasket went in the rsx.. my luck.. lmao
                            Still nothing. Replaced the coil
                            JDM_DC5<3
                              wtf?
