so I've been doing my research~ i have an 90 ef shell and im trying to slap this 95 ls in it, i know it is possible cause im looking at it right now in this "project car tuner" magazine. from 8/29/08 but its not showing how to do it:confused: people are telling me it cant be done, i wanna go for it but where to start???? i have both of the harness and ready to convert my obd0 to obd1... come on CT help me out, im new to this stuff~ lolbanna
converting obd0 to obd1???
Originally posted by ManTyme View Posttake your injectors and altenator from your b16 and swap em over to the ls......then you will need an obd0 intake manifold and dizzy unless you wire up the dizzy and you should be all set
korea at AF performance sells obd0 to obd1 jumper harnesses for dpfi to mpfi and everything is there (four injector wires,dizzy wires) to go directly from your obd1 ecu...with that you can use your stock harness and that jumper harness with an obd1 ls full swap!
or if you can get a regular jumper harness for obd0 SI to obd1 i can multiport your car for you using the stock daulpoint harness...just let me kno if you wanna do it and we could work something out...or if you have any questions pm me
