fuel fllooding need help
  • fuel fllooding need help
    built block and just installed a fully built head... all done at the machine shop... the works... everything done to it... and i installed it... was driving normal... but than i was on my way to work... and the fuel started flooding like crazy... i went through 3 tanks of gas on the way home from work... the gas is litterally dripping out of the headers... it boggs.. WHAT SENSOR WOULD CAUSE THIS TO OCCUR?? I NEVER ACTUALLY HAD THIS PROBLEM BEFORE... the only thing i didnt do is use the computer that came with the head when it was dyno tuned... there is no check engine lights at all either... HELP ASAP... thanks...
    and the head is also fully port and polished along with a 5 angle valve job.... im using the computer from my old setup...
      Map sensor?
        just tried it... no go... its crazy as hell... gas would just drop down... i got 440 injectors too... bout to swap them out and see if that is it... or change the computer...
          It's ecu or injector prob for sure.
          J-ROC TUNING
            problem solved... it was the injectors not working right... they were staying open the whole time.. replaced them now it is perfect..
              Good shit.
              J-ROC TUNING
