injectors
  • injectors
    in my all motor gsr my comp ratio is 12.5:1 what size injectors should i use if im getting buddy club stage 4 cams
    bump for all motor!
        450s should work fine
        203 Crew Memeber # 57
          450 or higher, depends on what is your red line. If you go to 9000rpm bigger injectors are better
          Crx 18 psi 441-308
          crx. 20 psi 400-270 DYNAPACK
