eg manual steering rack
  • eg manual steering rack
    looking for a manual steering rack from an eg cx/vx also could be from a delsol in good working order.not concerned with the condition of the tie rods.....also the c bracket that holds the rack to the subframe....i could be reached at 860 402 4977 or pm here thanks.
    CGP CL9
    1993 EH3
    some body's got to have this...
    CGP CL9
    1993 EH3
      You should be able to get a remanufactured rack from any autoparts store or eBay for about $125.
      Make sure you really want a manual rack. It's 4 turns lock to lock. Unless you need to save weight , are worried about the tiniest bit of parasitic drivetrain power loss, and are building a straight line only car, its a downgrade in stock form.
      Furthermore, every integra power rack is only 3 turns lock to lock and bolts right into your car.
      The C clamp from a manual rack will not work with your subframe. You would also need to have a front subframe from a car originally equipped with a manual rack for the bolt holes to line up at the C clamp.
      You can easily use your subframe and power rack C clamp with the manual rack.
      Just shim the manual rack simply by using an extra bushing inside the C clamp from the power rack. I used poly. If you use rubber bushings and double up on them, there is a chance of too much compliance.
