people want stupid prices for used parts, so I bought it all new for both my cars.
I got the local acura dealer to sell me an itr sway for $82. Energy suspension d brackets w/ poly bushings will run about $18 shipped. FCPimport sells the endlinks for $4/side. bought all the bar end bushings, collars, and bolts for $15 from Honda or an Acura dealer. I have part numbers for most of this stuff.
This will help a lot with part # ect..
If you google "OEM parts (Acura integra or Honda civic) Rear Lower Arm, you'll get a exploded view diagram, that lists all the parts necessary, but it also might be confusing for some. So, I will list all the parts and numbers. I'm in a giving mood today.
I ordered the sway from Acura but the rest from Honda which are the same but have different part numbers, so to simplify it for yourself you may want to get the Acura #s to make one trip to the dealer. but the list will still help you figure out which pieces you need.
Only part I didn't get OEM was the endlinks because I think they were $20/side or more from the dealer and I got them for $4 and change elsewhere.
on to the #s
-Acura-
USDM iTR 22mm Rear Sway Bar 52300-ST7-Z01
-Honda-
# on Diagram/Quantity Needed/Part Number/Item Name
#8 /2/ 52312-se0-000/Bar End Bushing Collar
#11 /2/ 52316-sa5-000/Bar End Bushing
#32 /2/ 90120-sb0-003/Bolt that goes through sway
#42 /2/ 92101-08035-0H/Bolt that goes through endlink to LCA
#41 /2/ 94103-10400/Washer
^ some of that stuff could be reused if your car came with a rear sway
I like to use the Energy Suspension D brackets and Poly Bushings.
Part # 9.5126G or 9.5126R
the endlinks can be bought from FCPImport which is based in Groton
^ thanks. Mine does have a oem rear sway bar. I'll have to look into that at Acura. I work at honda so I can get a discount on all the stud from honda and then order the bar from Acura.
No problem.
my del sol had a rear sway before the upgrade, all I purchased for that one was the sway bar, bushings/d brackets,and bolts for the brackets that go into the subframe brace. but I just got all new bushings because after all they are 20 years old. I just transferred everything else.
BTW, first time I called the dealer they wanted list ($104), I shot them an email stating if they'd match online prices I'd buy local and they sold it to me for $82. you can prolly get it cheaper obv through your job, but anyone else can save some coin that way.
