Need a auto d series tranny asapppp. Will trade 5spd one for it if anything.... Broke my girls tranny trying to put bell housing bolts in. Need this ASAP lmk
Wtb ASAP
So I assume u didn't put the converter in correctly so when u went to bolt the tranny up it put pressure on the case and it cracked. If it doesn't leak and runs ok leave it alone as long as it still holds decent pressure. If it dose leak either weld it or get a junkyard tranny swap the cases and return it saying the case was broke.
Originally posted by 94-civic-coupe View PostSo I assume u didn't put the converter in correctly so when u went to bolt the tranny up it put pressure on the case and it cracked. If it doesn't leak and runs ok leave it alone as long as it still holds decent pressure. If it dose leak either weld it or get a junkyard tranny swap the cases and return it saying the case was broke.
