Calipers
  • Calipers
    Looking to buys rear calipers and caliper brackets for an integra type r.
    if some has five lug trailing arms complete would be interested in buying that also.if any buddy has the following or knows any body who do please pm me or text/call at 860 402 4977. thanks
    CGP CL9
    1993 EH3
    You can use rsx or ep3 si hatchback rear calipers with brackets .they will mount and work.would have to use the right side on the left and the left side on the right in order to mount the emergency cables.you will require civic or integra emergency cable brackets .
    Originally posted by knuckk
      Or just go to advance and get some brand new ones with warrenty
        I was hoping you would reply. I knew you had written some info on k20a. Org but u edited all hour post.... So i have itr five lug trailing arms but missing the calipers and brackets. So if i were to get rsx calipers i wont need rsx hub/ bearing and they would bolt right up and rotor centered?
        CGP CL9
        1993 EH3
          Well if worse come i will ve to . But they are reman . I am just picky and want to have the nissin calipers....
          CGP CL9
          1993 EH3
            Yes..will work..you won't need anything else but what I mentioned.you can use the itr rotors,hubs,etc..only down side is that it will be a pain in the ass to bleed your system since the bleeders will be facing down.unless u install them without e brake cables.if u want e brake cables,then u have to place them upside down.will bolt right up.can pick some up at a junkyard.try chuckandeddies.com ..there are codes out there to save you 20% on your purchase..lmk if u need a code via inbox
            ***i edited all my posts all over several forums including ctvtec because I got tired of people talking shit. it took me several days/hours after hours of reading and trial and error for me to figure out what works and what doesn't work and some people don't know how to appreciate the knowledge and info that I provide at times.
