I'm looking to buy a obd1 scanner or if Somone can scan my car for me I switched ecus an my check engine light came on it hasn't bothered me but now it is lmk
Obd1 scanner or if someone can scan my car
Under the glove box on the right hand side there's a small blue plug that doesn't go to anything. You take a paper clip and put an end in each hole, then turn your key to the on position. The CEL will blink slow blinks and fast ones. Every slow one counts as 10 and every fast as 1. So say it blinked 3 slow and 4 fast that's 34. Then just hop on google and look up 95 civic check engine codes and you should find a key with all the different codes.Last edited by jdmjunkie9753; 02-10-2013, 07:35 AM.
Originally posted by jdmjunkie9753 View PostUnder the glove box on the right hand side there's a small blue plug that doesn't go to anything. You take a paper clip and put an end in each hole, then turn your key to the on position. The CEL will blink slow blinks and fast ones. Every slow one counts as 10 and every fast as 1. So say it blinked 3 slow and 4 fast that's 34. Then just hop on google and look up 95 civic check engine codes and you should find a key with all the different codes.Always on that fire
Correct that always works for me ...g/LThe Power of Dreams
