need these parts
asap
for ek coupee
all for a d16y8
-Transmission
-Pedal assembly
-Shift boot
-Shift boot panel
-Shifter
-Shift knob
-Shift linkage/bushings
-Manual starter
-intermidiate shaft/axles
-Linage bolts
-Flywheel cover
-Flywheel
-Clutch
-Realease bearing
-Pilot bearing
-Auto to manual mount
-Clutch master cylinder
-Clutch fluid resvoir
-Cluth slave cylinder
-Clutch lines
-Manual cluster
-Manual ECU
-Rear T bracket
-Upper tranny mount
-Front lower tranny mount
-Flywheel bolts
-Starter Bolts
-Engine/Tranny stifffener
-Stiffener bolt
asap
for ek coupee
all for a d16y8
-Transmission
-Pedal assembly
-Shift boot
-Shift boot panel
-Shifter
-Shift knob
-Manual starter
-Linage bolts
-Flywheel cover
-Flywheel
-Clutch
-Realease bearing
-Pilot bearing
-Clutch lines
-Manual cluster
-Manual ECU
-Rear T bracket
-Upper tranny mount
-Flywheel bolts
-Starter Bolts
-Stiffener bolt
