need a harness asap must be rsx type s only.. un cut and in good condition
WTB: k20a2 (rsx-s) engine harness
Originally posted by B18c1-Kat View Posti have one but first need to find out if i need to use my 05-06 harness with my k20z1 swap in my 02-04 rsx or use the k20z1 engine with the 02-04 harness shit got me lost on the rsx forums
Originally posted by JDM_DC5 View Postyou definatly need to use the z1 engine harness because i don't think yours will plug in to it with all the sensors.. your using the z1 tranny too?ALL MOTOR RSX
Originally posted by B18c1-Kat View Postyea full swap z1 i was reading to just use the 02-04 with a speed converter box or use full z1 everything and get kpro and use a step down harness the runn a 02-04 kpro this shit got my mind doin the 2 step
You have to use the 02-04 engine harness with the 02-04 ecu if you don't use the the converter box for the speed sensor your spee*********mer won't work.
Originally posted by B18c1-Kat View Postso with the speed converter box everything will work fine????
Yeah that's what it's made for or you can modify your tranny and put a eletric speed sensor because the 05-06 type s trannys have magnetic speed sensor and have no plug on the tranny for it.
Originally posted by allmotork24 View PostYeah that's what it's made for or you can modify your tranny and put a eletric speed sensor because the 05-06 type s trannys have magnetic speed sensor and have no plug on the tranny for it.ALL MOTOR RSX
