Complete lsv turbo swap come with:
B18b1 bottom end built around 300miles ago
Scat rods
wisco 9.1:1 pistons
oil pan taped for turbo return
New Acl race bearings
New rings
Shimed oil pump
96 gsr head
Type r cams
itr spings
Sk2 cam gears
1000cc precious injectors
lasky fuel rail
golden eagle oil feed lsv kit
arp head studs
aeroaeromotive external fpr
victor X intake mani
sk2 70mm alpha TB
gm 3 bar map
2.5 turbo piping
ram horn manifold
garrett tubo ar.70 turbo
custom 750hp inter cooler
tail BOV
tail waste gate
3" down pipe
3" thermal exhaust system
96 spec itr 4.4 final drive lsd
shift linkage
Stock clutch and flywheel
No starter
shifter
axles
Also come with
95 ls wiring harnes
resister box
Aem wide band
turbo oil pressure gauge
engine oil pressure gauge
coolant temp gauge
boost gauge
hasport motor mounts eg/dc
mishimoto half size radiator
Ecu chipped by bave
dyno sheet
I might be forgetting some things
2700$$ obo
located in East Hartford
pick up only
Dyno sheet available to buy
(860) 280-8361
Scat rods
wisco 9.1:1 pistons
New rings
Shimed oil pump
96 gsr head
Type r cams
itr spings
Sk2 cam gears
lasky fuel rail
arp head studs
sk2 70mm alpha TB
gm 3 bar map
2.5 turbo piping
ram horn manifold
tail BOV
tail waste gate
3" down pipe
shift linkage
No starter
shifter
axles
Also come with
95 ls wiring harnes
resister box
Aem wide band
coolant temp gauge
boost gauge
Ecu chipped by bave
dyno sheet
2700$$ obo
pick up only
(860) 280-8361
