Fully Built B-Series Turbo Setup
  • Fully Built B-Series Turbo Setup
    For sale I need $5000obo for everything only things missing to be running is distributor, and oil lines for turbo.
    txt 2033833525
    ****will part-out only big stuff like head,block,turbo setup****
    *******(prices are what I paid for parts just to have an idea of how much money is into setup)********
    1997 GS-R BOTTOM (0 miles)
    -9.7.1 wiseco pistons 81.5mm bore (combo rods and pistons $780 rsp.com)
    -Eagle rods h-beam ^^^
    -ACL race bearings $150
    -OEM Type-R oil pump $150
    -cometic head gasket $100
    -ARP main studs $100
    -cometic bottom end gasket kit $50
    -OEM GS-R water pump $100
    -supertech block guard $100
    **TOTAL FOR BLOCK PARTS AND MACHINE SHOP $2600**
    JDM B16 HEAD (0 miles)
    -supertech valves $270
    -supertech springs, retainers $330
    -supertech valve seals $25
    -mild port
    -ARP head studs $140
    -blue powder coated valve cover $100
    ** TOTAL FOR HEAD PARTS AND MACHINE SHOP ASSEMBLY $1600**
    ADDITIONAL PARTS
    -GS-R tranny $450
    -skunk2 manifold 1st gen $250
    -skunk2 70mm pro throttle body $300
    -golden eagle fuel rail $100
    -golden eagle sandwich plate $80
    -aeromotive F.P.R -$150
    -top mount turbo manifold $700
    -tial 38 mm W.G (v-band) $280
    -NGK blue wires $60
    -greddy type-rz B.O.V $250
    -walrbro 392 inline pump (255lph) $100
    -3inch v-band downpipe $250
    -p28 chipped out $150
    -greddy intercooler $300
    -dual core racing radiator w/slim fan $150
    -C.C ultra light weight flywheel $200
    -clutch kit $250
    -GARRETT GT3082R TURBO $1400
    ******TOTAL COST OF BUILD $9600******
    Everything is assembled and ready to go.. Everything professionaly done
      damn thats everything i want for my white coupe but i cant see spending all that cash cause like you id feel like id never make anything back at the end, but bump for a nasty setup if i wasnt all about saving my cash id spend the money on that asap, its well worth what your asking.
      if i was you id part it out youd make more of your money back
        x222
          Bump for beasty and legit set up
            With a good tune this swap looks like it can put good numbers glws
            J.R. Built not Bought
              bump for a nice set up
                  Bumpppp will part, head, block,tranny, and turbo kit after those start going ill sell all the small stuff let's get this sold ppl
                  Thanks for the bumps also ppl
                    nice setup bummppp
                      Flat valves sucks and leads to failure since they add some kinda compound in the middle which sucks...........bump for you because i am building a f22 build like yours but with forge piston
                      mr.snuggles to you bitch
                        USMC
                          Never heard of that and I'm pretty sure wiseco pistons are forged.. I have a friend that has the same head and hes been with the same setup going on 3 years now and he beats the living shit out of his car with no problems.. maybe the ppl you use to assemble heads are doing something wrong?
                            Damm over 300 views and no cheddar... Honda game gettin weaker and weaker smh
                              There's nothing wrong with flat valves and Wiesco pistons are probably top 5 lol
