Biggest baddest b series out there for sale
  • Biggest baddest b series out there for sale
    I have a jdmb20b darton sleeved block 86mm bore decked block arp main studs endyne girdle line honed acl race bearings brand new oil pickup brand new type r oil pump brand new water pump Moroso oil pan micro polished ls crank eagle rods wiseco 14.5 comp pistons have head on block head is a fully built Gsr head with full supertec valve train guides seals everything head was professionally ported and polished with competition valve job with bowl blending has flat valves 2 bump compression higher head was also decked also comes with golden eagle lsv kit 8.8 lb comp flywheel and Gsr tranny no intake mani just block and head will also throw in a Gsr tranny this motor was assembled by rce machine in new Milford ct if you want a k killer this is motor for you I will promise u with good cams this motor should put down 260 plus whp on the low side asking 3500 firm no money to finish
    Bump from the Bronx glws
      niiice
        bump for all motor setup!!!
        One Tire Fire !!!!!!!
          Bumppp
            Bump for rce they do good work had them do the head on my gst.
              Anyone who wants 2 clean up buy this
                Bump glws
                J.R. Built not Bought
                  Also have a 96 Gsr shell for sale was stolen and recovered 1000 takes it
                    Super high compression 260 wow if it does put that hp down big if for 3500 glwys
                      It should put more than that depending on header intake mani and cams last setup was all motor Gsr put down 232 on race fuel
                        Nicee
                          bump this need gone
                            Bump g/l on ur sale
                              holy mother of compression glws
