Air ride kit
  • Air ride kit
    i have an almost complete air ride cylinder setup will fit ex/ej/dc and more. comes with brackets. it could be used as is or add a few more parts to make it complete and daily driveable.
    $500 firm.
    this setup would easily run in the $2000 range new and needs very little.
    Trades for coilovers +cash
    or nitrous kit + cash
    thanks for looking. please bump.
    what it comes with:
    4 cylinders with brackets (one for each corner)
    prewired switch box with 7 switches
    compressor
    7 gallon air tank
    bunch of air lines and fittings
    manifold style valves (sometimes called an air engine) this thing will allow you to control all 4 corners seperately. cheap kits only come with 4 valves so you can only control the front and back seperately.
    in the process of rebuilding the valves. they are a little sticky.
    i made a pixelcar for my sig but i'm too lazy to pm a moderator.
      what size is that compressor? what valves are they? any dump controls on them? what kind of bags are they?
      590852836f5fbce940_b
        its all from airbagit.com the compressor is the dc7500. dump controls? as in adjustable slow down valves? i have 2 of them and 2 air mufflers. got the kit used and tested everything.
          yeah, dump controls being the adjustable valves to regulate the speed it blows off air. quiets the valves down too... im not a fan of them, but just asking for more info to potential buyers.
            Yea. On this setup the dump controls are almost necessary unless you want to hop the car. It's all 200 Psi rated and at 200 psi on cylinders it will lift extremely fast. I like the sound it makes but its a lot easier to brake something without them. I have done some work on some friends minitrucks with bags so I know a little about how this all works. This setup will be sick on whichever car it goes on. with cylinders you can 3 wheel around if you wanted too.
              Bump!
                bump for groceries!
                Down Since 09 ...
                Mugen Inspired DC5
                  iif only they were for my jetta:/ oh well glwys
                      cheap price,someone wants a hella flush look with out screwing with there ride quality
                        Bump cuz I need the $$ for some go fast parts.
                          Bump.
                            uh i just need the bagsss
                            Ef/Ek/DC5
                              RUN YOUR CAR NOT YOUR MOUTH
