massive partout!!!
  • massive partout!!!
    getting ready to get rid of the rest of my parts car,black 94 integra ls,tan interior,no swap,no front end,no rear bumper,no taillights.so heres whats left.
    INTERIOR
    have all the interior plastics
    rear quarter plastics $20
    headliner(for sunroof) $10
    kick panels(the ecu cover and other side) $5
    rear window trim $5
    cargo cover $10
    steering column covers $5
    center consol/arm rest piece(ugly as hell plaid wrapped) $10
    dead pedal $5
    sun visors $5
    dome light $5
    glove box $5
    EXTERIOR
    doors with good tinted glass $40 a piece or $75 for both
    trunk with good tinted glass $75
    RANDOM PIECES
    abs control computer $10
    clutch hose,closest to slave cylinder $5
    cruise control box with cable and harness clip $5
    brand new dizzy cap $10
    clutch master cylinder $20
    brake master cylinder $20
    abs pump $10
    grant racing steering wheel with hub adaptor and horn button $30(looks exactly like this but with red inserts where the thumb pads are.and it has this horn button
    obx catback exhaust with high flow cat $100
    ENGINE PIECES
    (2) stock fuel rail $5 a piece
    (2) stock fuel pressure regulator
    (2) stock intake manifold $10 a piece
    crank pulley $5
    timing side motor mount post(the 2 hole that are crooked) $5
    head with valves,springs,retainers,cam caps..only missing the cams $40
    lower timing cover $5
    upper inside timing cover $5
    block with spun main bearing,pistons,rods,crank,main caps,all intact. $50
    oem ls tb with no tps and no map,has fitv underneath will come with new gasket $20
    skunk2 70mm tb with blox tps(already adjusted) and brand new gasket $260
    have more so if you dont see it just ask and ill get back to you.everything is best offer just need to get rid of this stuff,the shell is going to the junkyard soon so lemme know.
    !!!!!ThE GoOd DiE YoUnG!!!!!
    Text me bro
      bumpppppppppp
        does that dizzy work for a gsr?
          i use to run my gsr head we a ls dizzy just cut a leg off n my boy del sol the same usin a ls dizzy on gsr head glws
            there ya go lol.the dizzy is on my car working right now.
              bump make me some offers,i know those prices are already low.
                G/L On Sale Bro
                gif
                  bump for ppl interested but not comin out to get some shit
                    Yo I want the dizzy,injectors,nd that map light
                      Glwys
                        You Got throtel body )?????
                          i think i have an ls tb..ill go check now.
                            power door panels SOLD@!!!
                              added oem ls tb and skunk2 tb
