all the parts need a new home because i dont need them. but plz make a offers on somethign you want but dont low ball.
Ihi warenerishi turbo t3 flang no play with down pipe flang 110$
sohc budget turbo set up 225$ Hf manifold,BMC race adapter, Evo3 turbo,02 housing,and oil fittins.
Twin turbo set up off a supra one turbo looks like it MIGHT be a replacement othr turbo has a chipped fin both working on stock car befor removed for big single 200$
D16y8 head with vlavecover and vtec solnoid 100$
d16y5 head with valvecover and vtec solnoid 100$
D15b7 head no cam all working cam was used for a core 50$
D16a6 intake set up all accys on it from a 1991 crx si 50$
d15b6 HF intake set up all accys on it 50$
4 sohc 16v non vtec valvecovers 20 each$
wrinkle red sohc Vtec valve cover 50$
spray bomb gold sohc vtec valvcover 20$
b20 valvecover needs repaint 30$
crx 5 speed HF tranny 150$
crx shift linkage 25$
crx HF clutch 89 only 70k miles 25$
crx ALT HF with 70k miles 40$
2x driver side crx mirros 25 each$
one crx head light (not sure side have to look again ) 25$
crx SI dizzy 75$
crx DX dizzy x3 50$ each
obd 0 LS dizzy i think 50$
HF crx crank pulley 20$
LS crank pulley x2 25$
crx tail lights outter only 30$
hood latch cable EF 20$
T bar for crx 20$
front rad support cut from CRX 75$
90 si rear bumper crx 50$ red
B series ALT newer with bracket 70$
pm5 ecu 20$
pm6 ecu 30$
p06 auto 30$
p06 stick 40$
pm8 ecu 20$
JDM parking pole with switch and pig taile works with green light 125$
2000 integra typeR need to be finished 43k miles clean orig title with d16z6 swap 6700$
Y8 water pump used x2 10$
LS waterpump used 10$
GSR water pump 22t used 15$
factory EF alloy mesh wheels 13'' 100$
EG antenna block off with gasket never used 20$
sohc starters x2 30$
bran new ebay EG blinker light clear clean never used 20$
brand new EK coupe side skirts aftermarket 50$
brand new pistion rings 75.5mm sohc 50$
2005 kfx 400 with mods minty and fast 2700$$$$$$$$
2004 crf 50 very modded street legal with light and red barron frame and the list is long 140cc 2000$$$$
1985 atc 70 with lifan 125cc motor new tires new seat cover needs new fuel lines.700$
misc parts left from 89 crx HF with 70k miles
1987 honda 250R pretty quick has a pipe carb work new berings in the axles new breaks hole shot tires nerf bars (not pictured) new cables.2200$
crx SI dizzy 75$
T bar for crx 20$
pm5 ecu 20$
pm6 ecu 30$
p06 auto 30$
p06 stick 40$
pm8 ecu 20$
