jdmnyc1 f/s thread alot of good part check .......
  • jdmnyc1 f/s thread alot of good part check .......
    first turbo kit real shit ...
    T04E COMPRESSOR WHEEL: 50.
    TURBINE : .63 AR;TURBBINE WHEEL: 62.
    INLET:3.0'';OUTLET: 2.0''.
    TURBO MANIFOLD FLANGE: T3 FLANGE; DOWNPIPE FLANGE: 2.5''5 BOLTS FLANGE.
    TYPE OF COOLING: OIL COOLED ONLY.
    TYPE OF BEARING: JOURNAL BEARING.
    HORSEPOWER RATING: 300HP-650HP
    0.4G'S @ 73.000 RPM;OIL FLOW 26.71ML/SEC.
    * INTERCOOLER GREEDY:
    * Size 27.5x11.75x3 With 3 Inch Inlet/Outlet.
    * Low Pressure Drop - Large Cooling Area - Easy Install - Tube And Fin Style Intercooler.
    * UNIVERSAL 3'' PIPING KIT:
    * Made of 6061 Aluminum. 3 inch Diameter Piping Kit With High Quality Silicone Couplers And T-Bolt Clamps.
    * The Couplers Will Not Split Easily + The Clamps Will Not Strip Like The Cheap Kind.
    * Strong & Tighter Fitting Use Hair Spray Between The Pipe And Coupler.
    * Mandrel Bend 3 Pipe(As Shown As Picture) For High Flow And High Horse Power And Better Turbo Response Power.Some Cutting And Modification
    Turbonetics Evolution Series Wastegate 10780...
    * 44MM WASTEGATE :
    * All Stainless Steel hardware, Mating weld flanges are 304L.
    * Set At 10 PSI,Come With Two Extra Springs,One Is 11PSI,One Is 25PSI.
    * BOOST CONTROLLER:
    * Allows Adjustable Boost PSI Settings, Light Weight Design To Be Mount Under The Hood. Hardware Is Included.
    * Manually Control turbo boost up to 30 PSI.
    * OIL RETURN LINE:
    100% BRAND NEW, HIGH QUALITY ALUMINUM.THE RETURN LINE IS 17 INCH LENGTH.
    HELPS CIRCULATE OIL FROM THE TURBO TO THE OIL PAN, WORKS ON METAL OIL OANS ONLY.
    * OIL FEED LINE:
    * 100% Brand New, High Quality, Never Been Used Or Installed!
    * The Oil Feeding Flange has Restriction build in, offers proper Oil Feeding to the turbocharger.
    * The Length Is 37 Inch.
    * VIBRANT FEEDING LINE
    *VIBRANT BUG FOR THE VALVE COVER
    *VIBRANT PLUG FOR THE BUG IN THE VALVE COVER
    GREDDYTURBO BLOW OFF VALVE BOV:
    * CNC Billet Aluminum, Dual Stage Handle, High Boost Power,Easy Mount Piping Set Included For Bolt-On.Including Bov Blow Off Value Flange.
    * Fast Fesponse One For Low And High Boost Pressure.
    * FUEL PRESSURE REGULATOR WITH GAUGES:
    * LIGHT WEIGHT POLISHED ALUMINUM, INCLUDING THE HARDWARES AND HOSES FOR INSTALLING.
    * MAX UP TO 140 PSI ADJUSTMENT TO MANAGE YOUR FUEL SYSTEM REQUIREMENT, INCREASE FUEL DELIVERY BY RAISING PRESSURE, GAIN 5-10 HP.
    *2 MOROSO OIL CATCH TANK:
    * Made Of Billet 6061 Aluminum, And TIG Welded W/ Billet Aluminum CNC machined.
    * Will Ensure Better Performance And Better Mileage On Your Engine. Mounts Above Your Valve Cover And Ensures Excess Dirt And Oil Does Not Get Inside Your Engine.
    * Dimensions: 6.25''x3.25"x3.25" , Holds up to 750ml.
    *PRECISION 680cc INJECTOR
    *3 inch VBAND EXHAUST
    *3inch DOWNPIPES
    *NEUKIN EQUAL LEGHT MANIFOLD WITH T3 FLANGE 44mm .
    *PURPLE HALLMAN PRO RX MANUAL BOOST CONTROLLER MBC
    *RED VIBRANT TURBO PIPING HOSE
    Much More but just ask ……. $ 900.00
    nx nos kit
    nx nos kit
    res nx bottle
    aluminum nos lineas
    fuel rail
    N2O-FUEL
    nxl clock
    much more .....$500.00
    b20z block ...
    b20z block with all internal
    nothing missing ..... $sold sold sold
    gsr tranny ....
    2001 gsr tranny little grind in high rpm in 3 gear some time not every time ....$ 375.00 firm
    2000 b16 head ...
    em1 b16 head with everything nothing missing ...... $ sold sold sold sold .00
    call me at 401 243 4200 thanks .....
    DOMINICAN CREW MEMBER # 256 .... http://4gifs.com/gallery/d/165025-1/Asians_smashed.gif?
    bump glws
      glwys bro
      The Power of Dreams
        Thanks guys .....
          if u want to sell the moroso catch can hit me up
          J-ROC TUNING
            bump for 401..
              Originally posted by bluxberryxhaze View Post
              bump for 401..
              all day jay ..... Prov
                $ 100 OBO each
                  Bump .....
                    why is tha numbers on tha b20 z grinded down?
                      cuz the turbo manifold dont fit the way i had it. so i had to grind the block to make it fit
                        bump .....
                          let me know if you wanna sell those motor mounts off the b16 head i need them for my car badly
                          EM1-860-CTmember..1...
                          J-SWAPS ....860-457-8335
                            glwys bro
                              G/L On Sale Bro
                              gif
