bumppppp
WTT For Swirlies/Blades/Twisties
yea. i took it all apart except coolant lines and didnt un bolt the head. Cuz I dnt have a 14mm or break bar n need buckets to empty the fluid into. But now Kyle wont answer his phone so I got no tools or car. But 2 rocker arms were just sitting in the head next to the valves. So that was my problem lol.Money ain't a thing! Crew Member #1
I was thinking about doing that to see if it runs good. And if it does then leave it. But at the same time 1 of the bolts that goes on the top of the rocker arm is missing so im assuming it bent that valve.Money ain't a thing! Crew Member #1
the bolt is for valve adjustment right?? if it is i doubt it did..run a compression test on it..
i just looked at the pix and whats missing is the valve adjustment screw and the nut that holds it tight..if they arent in the motor anywhere then it should be fine..just put one on it and get all the valves back to spec..i rlly doubt it bent a valve,Last edited by injen782; 12-03-2009, 12:33 PM.
