whoooooo man F/S something for everyone
  • whoooooo man F/S something for everyone
    well i been cleanin my basement and going threw my shead at work and home and this is about 1/4 of the parts i have for sale itss been on honda-tech for sale for a bit some stuff gone already. but WAY more to come!
    ok guys well i started to do clean up in my basement and in my shop to make room for the winter so there is lots of parts i have no need for and really not lookin to make a million off it all just like to make some room so pleses no trades.
    all prices are OBO unless stated FIRM.
    you must also add in for shippin a 3% if payin threw pay pal.
    if something is no pictured just pm me and i will take pictures for you if you want more detailed pictures also pm me and i will take some more.
    and sorry i will not ship any thing out of the USA maybe canada but i had to much BS with other places dont want to do it any more.
    all parts are also sold AS IS!
    well here we go !!!
    D16A6 crank shaft pulleys i have 3 of them on has rubber damanper in it looks to be stock
    20$ each obo
    D16Z6 vtec solinoid broken plug and broken presser sensor
    20$obo
    USED TYPER oil pump ruffly 1k miles on it pulled from the motor with bent valves
    60$ obo
    one full set of OBD2 injectors
    25$ obo
    one full set of OBD1 injectors with the safty stopper in the center
    25$ obo
    one full set of OBD1 injectors with safty stopper on the ends
    25$ obo
    D16A6 fuel rail with obd1 injectors and feed line
    30$ obo
    2 D16z6 fuel rails
    20$ obo
    D16Y8 fuel rail with FPR
    25$ obo
    2 bolt motor bracket
    25$ obo
    one full set of stock motor mounts from a 94 civic dx
    50$ obo or will spilt up pm me
    D16z6 lower timeing belt cover
    20$ obo
    B sreies tranny mount older one
    25$ obo
    misc shinny bent intake pipe with coupler
    25$obo
    GSXR 1000 ITB's good for the home made ITB guy
    50$ obo
    GSR/TYPER 22T water pump 1k miles on it
    25$ obo
    EF civic 2 bolt motor mount
    20$ obo
    D16Z6 timeing belt tenisinor
    20$ obo
    20'' Long earl SS oil feed line never used lost package but rember it cost me 29 bucks
    20$ obo
    4 16valve sohc valvecovers
    25$ each
    D17 coil on plug vlavecover
    25$ obo
    D15 valvecover
    25$ obo
    LS b18a1 valve cover powdercoated gloss black
    50$ obo
    SOHC VTEC accord valve cover powdercoated gloss black
    50$ obo
    ractive hedder rusty and the flang missing where it would bolt to the exhaust
    25$ obo
    ebay Rear strut bar
    20$ obo
    B18a1 intake manifold
    20$ obo
    B16a intake manifold
    25$ obo
    2000 GSR rack&pinion with tir rod ends on it
    75$ obo
    one NEW IN THE BOX B series axle driver side from autopart internotal
    70$ firm
    used passanger side ruffly 1k miles on it axle
    50$ obo
    hydro mid shaft B series
    50$ obo
    used B series starter 1k miles
    50$ obo
    D16Z6 block notched for forged rods empty
    50$ obo
    B20 crank pulley
    40$ obo
    2 /3 bolt motor brackets
    20$ each
    LS upper timeing belt covers
    30$ obo
    2 IACV
    20$each
    long throttle cable DPFI maybe
    20$ obo
    used 2k miles d16z6 oil pump with pick up
    30$ obo
    used unknow miles d16A6 oil pump with pick up
    25$ obo
    5 wire obd0 dizz
    30$ obo
    JDM D15B vtec-E head 4 new vlaves hot tanked and bence valve adjusted with stock JDM intake and injectors and Z6 valvecover.
    200$ obo
    Z6 intake manifold
    30$ obo
    EG cluster with tach stick shift
    50$ obo 200k on it.
    unknow sohc vtec aftermarket cam shaft no marking on it idk the brand lobs are def bigger tho then stock
    100$ obo
    BNIB HAsport hydro trans coversion for EF
    220 FIRM
    MINT gsr hydro trans lower miles never any grinds or pops loved this trans vin still on it with car fax report in hand.
    550FRIM
    ProLight B series flywheel fresh cut 1k miles on it
    75FIRM
    come clutch stage 4 6 puck unsprung 1k miles on it
    300 OBO paind 395+shipping so dont low ball it.
    LS/Vtec motor BUILT for turbo ran it for 3k miles tops never got any chance to dyno or track run it just break in and daily drivein and then lost my licens in the car sold the rollin shell on here about year ago and had planed to put the motor in my CRX but i am going back to the D series in it so this must go.
    i will part the head from the lower end and that about all i will part from it sorry just dont want to pull apart a good running motor.
    B18a block .20 over
    wisco pistons
    eagle rods
    knife edged and balanced crank
    oem berings
    typeR oil and water pump
    new seals
    arp head studs
    B16 head
    all new valves
    gsr cams
    comp springs and retainers
    AEBS intake manifold
    3k obo for the whole thing pm me for part out prices.
    next is the motor in my CRX now
    B18A ruffly 160k on it
    new timeing belt and water pump
    act clutch
    mint cable tranny.
    i will sell it as a swap with Axles HAsport mounts for EF and linkage with OBD1 dizz for 750FIRM
    or sell just the motor trans dizz for 500FIRM.
    the motor is still in my car for sale so any one in the are i will take for a ride befor pullin it only if you show with cash will i do it tho and i will not pull the motor till i get paied in full for it sorry guys.
    now for pics any thing you see listed not in a pic pm me and i will take some for you,
    thanks for looking
    axles sold
    ITBs sold
    turbo kit from my crx sold
      ok i dint read but i saw the pics. got one question for you is that torque mount/AC bracket from a LS if so i need that
      S3-R
      Stage3-Racing
        bump for good a$$ parts
          i will have to go look and match it up to my ls motor i have sohc ones i know and i have the passanger side tranny one form a gsr. let me get back to you
            alright just let me know trew PM. if it is i will buy it off you asap
            S3-R
            Stage3-Racing
              Bump for my boy Frank deff a good seller and the axles worked out perfect thanks bro.
              860 member #18
              puerto roc #1
              Cosa nostra
              ASAPRadio.net
                no prob danny glad to help
                  WILSON BUILT
                    pix of swap?
                      pix of swap?
                      of the LS swap? cheack my other thred for it titled EF/LS swap for sale
                        gif
                          bump for a good dude, i boght the axles, and i got my eye on the type r oil pump and water pump
                            let me know danny got my number
                              bumpz for alot of stuff
                              Originally posted by knuckk
