dohc ZC 5 speed tranny works for sohc also
  • dohc ZC 5 speed tranny works for sohc also
    low low miles on it it was droped and cracked the case but i pulled it apart and had the case welded back to stock and it works as good as new it did not have alot of miles on it to start with.
    175 obo i have it in the back of my truck so i will take some pictures in a few comes with a shift linkage and short shifter
    bump it up
      does the zc tranny jus have the longer 5th gear
      correct me if im wrong?
      :cool:
      #49
      2wo 0h 3hree
        does it fit on 93 coupe
        white people suck
          the zc is awsome, equal lenght axles, it has a half shaft. it is also cable so its for pre 92 civics.
          bump!
          NHSWAPS13203 > *
            it will work in the 92and up cars if you the conversion mount from hasport to make it fit in the car and you will also need a hydro to cable clutch conversion and the half shaft makes the sohc car that are making power so much easier to drive
              back to the top this ************ needs to sell
