DSM/4G63 Stuff
  • DSM/4G63 Stuff
    Most prices are obo.
    2G 4G63 turbo head - stock - 110K miles. Running when removed. $150
    2G 4G63 turbo head - stock - 150 miles on rebuild and bottom end started ticking. Head's fine. $300 complete w/cams & lifters.
    2G 4G63 7 bolt shortblock - rebuildable- Block has Evo 9 pistons, stock rods & crank ARP Head studs. No balance shafts. Cyl #4 is softly ticking under boost. 100% running when taken out. $300
    2G 4G63 7 bolt block and crank - Block is good, crank is pretty bad. - Spun rod bearing #3. $100
    1G AWD Buschur Racing 3 in turboback slip-fit exhaust. Downpipe was repaired previously (transfer case broke @ track and dented it.. replaced it with another section of SS 3 in pipe. $400
    3 Kumho Victoracer tires, 245/45/16 I flat spotted the 4th and threw it out. Still show the phantom tread pattern over them (7/32 or so left) $200
    60-1/T3 Hybyrd turbo. .63 a/r stage 4 hot side wheel. Complete with Chrome-colored Jet-Hot Coated cast iron manifold & Wastegate. Less than 10 miles and one dyno pull on the turbo, manifold is brand new as is wastegate. $700
    MSD Ignition - $100 - Never even installed.
    HKS SS BOV $50
    94 (23 spline?) AWD transfer case $120
    1G fwd transmission - $150
    Also have several small engine parts such as throttle bodies, intake manifolds, spark plug coils and the like.
    I'm also looking to get ahold of a few things I'd *CONSIDER* trades or partial trades for:
    2G FWD Shocks (any brand)
    2G FWD Springs of a small drop. Eibach pro kit preferred
    2G EPROM ECU.
    DSMLINK v3
    550, 660 or evo injectors
    *QUIET* fuel pump (190 Wal or Supra. No 255's).
    Working head unit to Avic N-1/N-2.
    ARP Wheel studs.
    Front & Rear shock tower braces for 2G FWD
    Stock AWD 93+ or aftermarket brake calipers and lines
    225/50/16 and/or 225/45/17 premium tires in a matching set.
    Email me if you have any issues or questions. I'm lazy about checking this page. pofoikz@gmail.com
    4G63 2.3L Stroker. 'nuff said.
    I got some 2154517 z conti pro contac's continental's 3 at 90% 1 at 75% ill take 100 firm..they hold air thats all i really know about them. They where taken off a car..i thought i would put it out there i know your looking for 2254517 if anything pm me
    WILSON BUILT
