Water/Methanol Injection Kits
  • Water/Methanol Injection Kits
    just wondering if any one here have try any Water/Methanol Injection Kits i have read about on other websides and people swear by it... but it is on different brands not on the honda
    SMC kit, Aquamist is awesome but very expensive, the AEM kit is good also.
    PINKS!
      I have a cooling mist installed on my setup. LS TURBO.
      My buddie is using devils own installed on his VR6 TURBO.
      Methanol Injection, Alcohol Injection, Water Injection, DevilsOwn
      No complaints from either.... I have used mine for 2 years now... 09 will be its 3rd year.
        water/methanol
        i guess my actual questions if it perform as advertise, cuz big enough injectors and pump we could put pleanty of fuel into that chamber... decrease the chance of detonation, increase the octane of the fuel with the methanol and cooling up the charge of air mass into chanbers with water... i know they have some awesome claims, Do they stack up as advertise... brand will matters of preference do that some people like chocolate better than vanilla but bottom line is if they do performace as claim!!!!!
          all you need to know. :)
            Absolutely..I make roughly 100 more whp with meth over straight pump gas.
            PINKS!
              And I run the SMC kit.
              PINKS!
                I run a basic Snow kit on my 2j. I run -20Fwiper fluid which is roughly 35% meth, 65% water.I had my windshield wiper reservoir modified to spray instead of installing their tank b/c i have no room in the engine bay. seems to work pretty good
                Precision 6265 gte
                  Does anybody have pics of a setup, im kinda interested now to see what it would look like
                  If it wasn't for haters i wouldn't be where im at today;)
                    All you basicly see is the pump. Port on the left is fed from TANK. Port on the right with the check valve goes before the throttle body, after the intercooler.
                    Ground / Power / Vacuum.... There is a small allen key that select when the pump will turn on...
                    I also wired up a LED light so I can see when and if my pump is turning on.
                      would i be able to use this on an all motor N2O setup?? or just replace the N2O
                        i think that you could used it do that it improve the gas octane ( i have read some where) about 6 point or so. remenber it only is using washer fluid which is very cheap
                          gents thanks for the assistant on my search of knowledge for a particular product... i will get me one this kit it seems like a very good investment for my search of power and performance. ones again thanks
                            My buddy has a kit installed on his all motor vr VW. Not sure on the brand, but he didn't bother with the tank they give you he just tapped right into his windshield fluid reservoir. Before he installed it it would be pinging even with quality octane booster. After installing the kit the pinging was completely gone. Now he'll be supercharging the motor using the kit just with bigger nozzles. So ya they work pretty good.
