Block guard or no Block guard?
  • Block guard or no Block guard?
    I've found mixed opinions on them. Looking to make somewhere in the 350-400 whp range but I want it to be reliable. Anybody have good or bad experiences with using blockguards.
    everything I've heard about them is that they do more harm than good. Restrict coolant flow and warp cylinders. 400whp will be fine with just a good forged piston/rod combo
      Sleeve liners are the way to go
      Follow me @bolacan413
      Follow the build @k_insight
        Just build within ur budget. If u can't afford sleeving a motor, keep your power goals with in a stock blocks capabilities. Talk to a tuner they'll help you.
          X2
            I made 513whp on my stock sleeves(no block guard), forged rods, forged pistons GSR block.
              I'm trying to get one my self.. Way better then block guard
                how long did the motor last?
                  realistically what is a stock B16a2 block going to hold for power reliably with a good piston and rod combo?
                    Originally posted by el abusador View Post
                    http://www.cylindersupportsystem.com
                    any idea on turn around time?
                      My motor has over 7000 miles on it so far and it's still going strong. Can't say that about my clutch though, I went through 2 clutches already, upgrading to a twin disk clutch for next season.
                        Like H22 said talk to your tuner. Most tuners would perfer a blockguard so that the comfortable pushing more psi. But the are alternatives to sleeving such as CNCWerx CSS(cylinder support system) (http://www.b20vtec.com/forums/engine...rt-system.html). I have heard allot of good about this method . I personally havent used it .
                        HWR
                        13203 RIP Nhswaps
                        School of Hard Knocks
                          Quick tip, don't bother with the b16 block. Go ls/vtec or b20/vtec but you're gonna have to sleeve the b20 block regardless. You'll get good numbers just doing ls/vtec with just bolt-ons.
                            Who tuned the car if u don't mind me asking?
                              That's what I was originally gunna do but I got a complete em1 swap with harness ecu tranny linkage and everything for under $600 so the b16 is what I will be using for this build. Plus 350-400 shouldn't be to hard to achieve with boost. I'll be happy if the car makes 330 I just want it to be reliable.
