turbo losing power
  • turbo losing power
    i bought a turbo kit from one of my friends but it seems to be losing power like before it had more to it but it has been used for a long time any ideas of what it can be...
    Check for shaft play and has your car been tuned ?
      I would say get the turbo rebuilt
      Ek coupe-dd
      Daddy to be
      Twisted Jokers Ac-Lieutenant
        ^x2
          check for a boost leak
          590852836f5fbce940_b
            x2
              no tune and ive been thinkin bout gettin a new turbo kit instead of messin around with this one been thru too much...
                Check for shaft play... Boost leaks... Ect.. do a compression check... Is it smoking at all?
                And i cannot insist enough to get it tuned!!! Its one of the best investments for any car, especially turbo.
                I like fast cars
                    agree 100%
                      It smokes when it boost but last time I checked it had lil shaft play
                        re-check your shaft play... take the filter off the turbo and see if there is oil in the compressor housing.. also take the inter cooler piping off the turbo itself double check to see if theres any in the piping..
                        whats on it for a restrictor?
                        is your drain as short as possible with no more then 45 degree bends?
                        i have a garrett turbo for sale if you need a new turbo, its almost equivalent to a gt30
                        a/r: 60
                        .82 exhaust
                        small 4 bolt down pipe
                        I like fast cars
                          I'll check in am and restrictor for what?
                            restrictor in your turbo feed line.. should be at the turbo end of the feed line..
                            I like fast cars
                              Check for shalf play
                              Check clamps and etc
