Block guardz
  • Block guardz
    Im going turbo and i i need 2 know?? Is block guard good or bad...i been hearing sum cooling issuesz wondering if any 1 has 1 or used 1 b4
    8thCivic.com
    any1???? plz tell me i needa kno if i needa order em or not
    8thCivic.com
      Block Guards are recommended, people just usually install them incorrectly, which create problems.
      Install the block guard as directed:
      1.) De-Burr the Block cooling jacket around the tops of the cylinders
      2.) Drop the Block Guard in (Do Not Push or Press in)
      3.) Level the block guard with Head mating surface of the block.
      4.) TIG Weld into place
      5.) Bore & Hone Cylinders
      6.) Machine Head mating surface of block.
        iight i didint think i had 2 do all that...so just placing it on....would proablly be the reason the heat sinks on the guard dont work right?
        8thCivic.com
          if you just drop it in and not hone your walls you will F*ck up your motor bad. aslo if your going to get one only get the GE one they have the best flow.
          ALSO you dont really need a BG unless your going to be running high HP numbers
          R.I.P Nick "NHSwaps" Haines 6/26/84-5/1/10
          Gone but never forgotten.
          13203!
            good lookin out i kno i dont realy need it but i was jus wonderin if it would jus make it a little less likly 2 detonate..i just dont wana put 2 much buildn money in da z6 i rather go ls turbo...da z6 is jus an intro to a lil more pwr
            8thCivic.com
              YO u got to stay single cam! that all i play with an i love my 1cam's better.
              but for real if yo dont know what to do with a BG then i would stay away or have it put in by a shop.
              13203!
                lol iight good look ima stay far away...i love my sohc but...i love boosted cars 2...and an ls can hold so much boost...but da money ima use 2 do a ls swap i can proally build a d16 boostin makn 300 + 2 da wheel so idk maybe i keep da single jingle
                8thCivic.com
                  A couple of years back i had a motor that lasted 2 years of track and street races and never give me a problem....27 psi and made 610 hp c16 81.mm stock sleved....block guard
                  but i built another block for way more than that....never had any problems.....tuning and set up is key
                  SFWD '2012'
                  DYNAMIC PERFORMANCE
                  FELIX TUNED
                    datz is wuz good...i wanna build some shyt like dat..and i realized the tuning is the key lol trust me ive seen why hehe:)
                    8thCivic.com
                      Stop listening to these guys man.....You going boost? Put a block guard in there....it's a $100 insurance for the cylinder sleves, but I'm telling you, get it put in at a machine shop, because if you try to do it yourself, you can easily make the cylinder slevees look like an egg shell instead of a perfect circle. I know this, it happened to me.
                      Anyway, there is really no cooling issues with them, if your car is properly built, you are going to have no problems.
                        lol yea wen i was askin about it my plans was to do it myself....but i guess i will jus do it the right way...YO DO U KNO ANY MACHNIE SHOP???
                        8thCivic.com
                          yo you know i know machine shops. slow mo
                            lol word we name callin ok jonny appleseed lol...but 4real i hit up lata u hit me up wid sum pricez on da machine work..but see thats ma problem if...igoona do this i might as well cop some vitaraz throw em in and boost hell out of ma single
                            8thCivic.com
                              Then Sleeve it
