going to build a ls block for boost. need advice for best or top pistons and rods for this. going all out on this so crank and all will be aftermarket. lmk ctv
block turbo build
Originally posted by evo-mentalites-cc View PostEagle rods stock crank 84mm sleeve kit 8-8 compression pistions and a lot of boost
eagle big bolts at least, or manely rods
stock crank
10-1 or up compression and 84mm. Use a vtec block so it has a girdle.Last edited by 93supercoupe; 11-10-2011, 04:43 PM.
u can do an ls, but they dont have girdle connecting the main caps on the crank. Golden eagle, full blown, earls, all sell girdles for the Ls's.
On my build its
84mm GSR
LS crank
10-1 CP pistons
Eagle rods with the bigger bolts.
What power level you trying to acheive?Last edited by 93supercoupe; 11-10-2011, 04:44 PM.
