d16y7 trying to go turbo need help!
  • d16y7 trying to go turbo need help!
    hey what's good ctv... i got a lil d16y7 in my eg and im tryin to boost it over the winter; so i have a nice lil set up for next summer.. my only problem is is that i'm new to all this and could use some help... i'm trying to achieve anywhere from 180-220 whp with the set up being complete... and i do have a budget... i'm not trying to spend an arm and a leg, but at the same time i'm trying to do stuff right; so this sett up will be reliable... Anyways i was just wondering what would be the best/good reliable parts to buy such as whhich pistons to go with, what turbo, what size injectors, should i get my head machined, headstuds, camshafts, all that stuff... please i need some good credible opinions... thanks ctv
    Just go b series
      get ebay full turbo kit it work im runin 1 and my hatch is a dd but pull 2
        hey bro i got a full single turbo kit and build head will sell the everything for $700
        pm me
          vitara pistons, blox valve train and cam shaft, arp head stud/rod bolts, golden eagle rods, port and polish, balanced crank, race bearings, bigger injectors, and you should be set lol. just do more research on single cam builds. best if you use the d16z6 block and a y8 head. single cams can make BIG power dont be fooled by what people say. you just gotta do it right.
            bump to jdmjoe commet
              Bump. Or atleast a z6 crank so you don't have oil issues
                for those power goals u dont even have to do that much, i would say stick with a z6 block so ur not spinning bearings, go arp head stud kit and slap that mofo on ull make 180 easy
                single cam ham
                  i have the turbo,650 injectors and p28 tuned at 290hp @16psi for single cam....$600 and you take it all
                    Wow
                    (860) and beyond
                    #DavesTuning 8608050968
                      I got brand new vitaras pistons never used with new rings still in the box 80 bucks firm picked. Up only lml
                      S3-R
                      Stage3-Racing
                        on a stock motor?
                          pistons rods head studs and you will be happy
                            I make 230 bone stock fucking z6 longblock with 160k David tuned ftw
                              eagle rods and vitara pistons
