hello, I'm changing my head gasket tmo and after its done, I want to turbo the car. what else should I change while I have it apart ?
turbo help
Upgrade the head studs to ARP. Use a Factory Metal Head gasket. You may want to take the head to a local machineshop and make sure it is level.
While you got the T belt off, change the water pump and tbelt tensioner.
Other than that if you dont want ot build the engine, you can get by on a mild boost level if tuned right.RIP NHSWAPS13203
ARP head studs, OEM Honda head gasket, Walbro 255 fuel pump, DSM 450cc injectors or bigger injectors of choice, and NGK BKR7E spark plugs gapped to 0.028 - 0.030 or smaller gap depending on how much boost you plan on running. Get a wideband O2 'cause you can't tune without it unless your tuner has a universal one. It's hard to say without knowing what you plan to make for power but yeah.Hidin' out
